Is this meter installation safe?
26 Dec 2012
This is a follow up to my post a couple of days ago about an Ovo engineer raising an AR on my meter box for the consumer side pipework exiting through the top of the box, to which several forum members commented on - many thanks!
I've since shown the photo of the installation to another meter installer who's comments were that he wouldn't have ARd it, but that he'd be more worried about the meter only being supported by the union fitting on the supply side.
So my question this time is: Is this meter installation actually safe, from the point of view of meter support? Should I raise a comlaint against Ovo to get them to rectify the support?
It does need supporting both sides but highly unlikely that OVO would have altered the pipework. It would probably have been like that on the previous meter installation
OVO have JS to do with outlet side.
Outlet side is your responsibility
It would seem the connector used is not appropriate for the meter bracket
hard to tell by photo have an actual look and see if there is a groove in the fitting on the outlet side (right)that slots into bracket
i have seen very similar fittings that are perfectly ok groove just hard to see.
If your on about left hand side that certainly looks like it has a groove into bracket
Thanks (again) for the response gas112. If I'm interpreting the responses correctly (?) you're saying that the means of support on the supply side - union fitting (is that what they're called?) with a groove in it is fine? There's definitely not a groove on the outlet/consumer side.
Maybe that's also why the Ovo engineer raised the AR, rather than taking the few minutes (and the part) to fix it.
Follow up question: Can I get a gas fitter to correct the outlet/consumer side without involving the supplier? Any idea what the "correct" part (i.e. the union with the groove) is called?
yeah no prob getting a fitter to fix it . looks 28mm pipe so this fitting
IF pipe is 22mm then this fitting
Meter changer is not there to change the connections, only swop the meter. Also, right hand side belongs to you so you need to get that sorted.
If the meter was sitting on a shelf, outlet connection would be appropriate
