Is this notifiable?
"Transformer" means change voltage.
A lot of transformers output 12V AC. That is fine for 12V halogen bulbs but no good for LEDs.Those transformers also typically have a higher minimum current draw that the LED fixture.
What does it say in the instructions?
A transformer is strictly AC to AC.
Something that changes mains voltage AC to a lower, steady DC voltage is a power supply. Some LED "drivers" are power supplies. Others are much more sophisticated, generating a pulsed DC waveform. These are drivers. Driving an LED with short, high current pulses give a brighter output than can be achieved with a steady direct current - it's to do with power dissipation in the LED die and the persistence of human vision.
Varying the pulse width and current can be used to achieve smooth dimming of an LED emitter.
NO. That is a D.C. power supply. A transformer transforms AC to a different voltage, still AC.
I thought that's the reason why they were called transformers.
They transform AC voltage.
I've learnt another thing.
Unfortunately the term 'transformer' has been hijacked in the last decade or so by advertisers to include both AC-to-AC and AC-to-DC voltage-changing devices. Before that it was traditionally used to mean just an AC-to-AC voltage-changer.
Only by those who thought that.
It's just a word that means 'to change'.
It can be used for anything that changes itself or something else.
I have to agree with Alec_t,
The original and accurate term "electrical transformer" became shortened to "transformer" and later when electronics could be used to convert a 230 Volt 50 cycles AC supply into a ELV DC source the accurate term "electronic transformer" was created but was soon shortened to be just "transformer". by marketing people.
The term " convertor" would be more accurate. Such as was used for "rotary convertors" where the electrical input powered a motor which drove a generator that produce the output.
I am not disputing what Alec said, merely pointing out that it is he and they who were wrong to do so and think everyone else has to think the same.
Perhaps the original and accurate term was "AC voltage transformer" (electrical transformer is even more vague) inappropriately shortened (which happens in lots of cases).
It is just an ordinary word being used for a specific device which does not negate the English meaning of the word for its other uses.
The same applies to converter, inverter etc.
... It's just a word that means 'to change'. ... It can be used for anything that changes itself or something else.
... Perhaps the original and accurate term was "AC voltage transformer" (electrical transformer is even more vague) inappropriately shortened (which happens in lots of cases). ... It is just an ordinary word being used for a specific device which does not negate the English meaning of the word for its other uses.
You're a day early :)
I'm not actually convinced that there are any "English meanings of the word for its other uses" which in remotely common use.
The verb "to transform" is obviously used very widely, in many contexts. However, when it comes to the noun "transformer", by far the most common use is in relation to the 'electrical/electronic' devices we are discussing. That is invariably the primary definition in virtually any dictionary, always talking in terms of AC voltage/current and often qualifying that with the absence of change of frequency.
Most dictionaries give a secondary definition of something like "A person or thing that transforms" (which is essentially what you refer to above). However, other than for the 'cartoon character'/toys, I cannot think of any other "thing that transforms" that is commonly, if at all, called "a transformer" other than the 'things that do things to voltage/current' we are discussing. There are plenty of things which we don't call "transformers" (although the dictionaries says that we could) but, rather, call them "converters" or suchlike.
As for "a person that transforms", it is also a fairly uncommon use of the word. Describing someone as "a transformer" is usually reserved for people who have done far more than just 'changed' something, particularly those who have "profoundly changed/transformed thinking" on some subject - like Darwin, Newton, Einstein, Hubble etc. etc.
So, I wonder what "other English meaning uses" of the word "transformer" (referring to "things") you had in mind?
Kind Regards, John
Well, you have quoted two such examples which verify what I have said. What more need be said?
