I've recently moved into a house and had all the electrics checked (can't remember what the actual compliance certificate was called).
The electrician said the system passed but, although not dangerous, the additions & alterations the previous owner made were 'interesting'.
There was a single socket in an outside building that I changed to a double RCD socket.
When I try and use a small fan heater off this socket it trips the fuse in the main old-style fusebox. The fuse that trips has an 8 amp rating and is the circuit for the upstairs lights.
If I changed this fuse to 16 amps, would it be safe?
