J
johnsville
You have an attitude problem.
No No, he has an altitude problem, ie the rest of us are mere underlings.
You've been told by at least eight people that you're cooker/circuit proposal is unacceptable and potentially dangerous.
Not acceptable to BS, but not dangerous electrically - the two at times may conflict. This is a case. The points have been taken on board. I was just generally talking about electrical thing that spun off the thread. Then got a lecture from an abrasive man with big attitude and it appears he has supporters.
BTW, I will not be doing it. I will double check if a small CU acting as an isolator with a 20A mcb can be off the ring. If that is the case then I am home. Most here say the regs do not allow that, if so then I am stuffed.
