J
johnsville
This is obviously a leg-pull. C'mon guys, he's had his fun, leave him alone now. He'll only come back with more silly ideas if you encourage him.
You can always come up with good work around if you like. Others have.
As previously pointed out the two legs MUST be of the same length to use as a radial otherwise one cable will carry more current than the other. I really can't believe what I've been reading in your posts John, and you claim to be an engineer? What kind?.... so I can stay well clear of your 'projects'![]()
I've no idea why you quoted me as it has absolutely nothing to do with your post BUT yes you have a possible solution... enjoy!![]()
Your opening post ruled out running a new circuit from the CU, but you think that people should have guessed that you'd be able to rip and replace two circuits within the kitchen and should have suggested that at the start?Thank you! Easy isn't it? That is why I came here. Some are good and think, others do not read properly and one has attitude. Nevertheless a solution was reached.
A ring is not the same as a parallel circuit.If the two cables are not equal length and one is drawing more current than the other, what is the big problem? That occurs on a ring anyhow.
Wheher you do or not is of no importance.Of course try to get them the same length, but if they are not quite the same length I can't see a big problem.
Lose yours then.No. But attitude does not help at all.
There you go again - trying to dismiss sound advice that you happen not to like by the application of ad hominem fallacies.Still have attitude eh. You added no value in getting a solution, others did, who I thank.
