Have ordered the cheap bucket tester. Will let you know how it goes. What sort of pressure should I pump it up to. Tks a lot
I had one pipe like that, I needed to keep the water pressure on the other end and keep working and rotating the steel strip I had, the bits then started coming out, it was over a metre of blocked before the "filter bed" gave way and I had full flow of dirty water. the compacted solids prevent the suspended crud from coming through and your blockage could get worse unless you persevere with it.OK I even tried to stick a steel drain cleaning tape down the open radiator pipe and only made it 5cm or so that was a fail. Would have expected the tape to have gone around any immediate bends under the floor as it is very flexible and thin. So maybe it is very local to the radiator.
How did you shift it pressure test from the valve to 20bar on the leg that was blocked. The blocked leg was still connected to the rest of the system?I once had a 10mm pipe up to 20bar before it went, needless to say one wall of the room the other end was in ended up a bit black, luckily it was being renovated.
No, I had access to both ends so I removed the valve at the rad end in the bedroom, used the nut and olive and connected the pump tester to that. T he connection to the main 22mm return was in the bathroom and I just cut that at the tee, blew out the pipe and then once clear just made a new connection to the return.How did you shift it pressure test from the valve to 20bar on the leg that was blocked. The blocked leg was still connected to the rest of the system?
Yes, the fact you are now getting flow through the system means it is obviously starting to work and the more flow there is the better it will get but as suggested it all comes down to how badly the pipe is furred up and it it harder stuff or not. The former will take longer to dissolve and you need to be careful with using X800 as it is quite aggressive.@Madrab left some x800 on the rest of the system and drained that out today. Filled up with water only and shut all other radiators off and got some flow now so radiator now gets warm. My bucket tester hasn't arrived so plan now is more x800 introduced into bathroom rad and let that circulate between boiler and bathroom rad for 10 mins then shut the bathroom rad off and let it just have the bad rad and boiler with the x800 for say 12hrs. Does this sound like a good plan? Bucket tester will be with me tonight so with the x800 in situ and the bucket tester maybe I can shift the crud?
