hi, not sure if i can do this so will ask you helpful lot
i have a set of 400 and a set of 200 blue and white led christmas lights from BandQ. they both are identical in every way, transformers wire configuration etc the only difference is the number of bulbs.
i turn both the lights on using an extension lead so they turn on at exactly the same time but they never run in sync for long- they start all flashing and changing colour at the same time but within a minute they are doing totally different timings.
my question is
can i cut the plug off one of the sets and then join/solder the string of lights on to the end of the other set?
if so what would be the best way to do this to keep it weatherproof?
cheers
steve
my question is
cheers
steve
