6” gutter and a 4” soil stack does the job. Makes your house look likes it’s on steroids though.
Coil of chicken wire in the top of pipe, not disturbed by wind and easy and cheap to replce.
I have a mesh rose where the running outlets are, but nothing beats cleaning out by hand where possible. Its also good to scrape out the debris where the lead valleys terminate too.
You could attach a hose pipe to the end of each run. Then turn it on for a few minutes every week in leaf fall season to flush it out.
Are the down pipes not connected to a surface water drain?Surely that would just flush the leaves into the downpipe. That is the opposite of what I want to do.
Amazon calls them 'Gutter pipe leaf wire balloons'........68 - 75mm.
I could try more substantial gutter balloons like this
https://www.amazon.co.uk/Gutter-Pipe-Leaf-Balloon-63-75mm/dp/B00FI0PEAI
or a strip of metal mesh along the gutter.
Any ideas as to whether either of those would help or anything else that would be good?
For sure they do stop the grot from going down the down comer but obviously the solids collect around the balloon so they have to be removed periodically for cleaning.
Fair enough that's why said do it every week but maybe it'd be more like every day!Yes, but if the downpipe gets blocked by leaves then nothing will flow down. There was a mass of leaves (mostly decomposed) above the gutter balloons but after I had cleared that the next section down (where joints move the pipe next to the wall) were pretty solid as well
I think that you mean that you roll up a long strip of chicken mesh, which will have lots of holes offset from one another. Thereby making a fine mesh.You coil the mesh ,create quite a fine filter and keeps all the leaves out.
In my experience, the downpipe balloons only make it worse, as they hold debris back that would otherwise wash down the pipe with no issue. You're better off cleaning the gutters more often, maybe flush the downpipes with a bucket of water
