Hi All
As part of my extension project with existing ground floor being open-planned, the design is to build a Goal Post structure, 2 Padstones, 2 Columns, Beam on 2 columns etc to open up a 6 meter wall.
Due to budget constraints and the fact we need to live in the house, we wanted to keep the existing wall up temporarily until the extension is fully erected and sufficiently waterproofed.
I have had builders that want to do the whole project in one go, some builders suggested it is doable, some builders suggested there is nothing holding the wall up once the beams and columns are in and thus unsafe. (If there was no columns, it would be more doable).
Does anyone have any thoughts as to the feasibility? Time scales is probably 1 - 2 months while the extension is build and roof put in with windows, floor concreted plastered etc.
Can i trust the builders who say it can be held up safely?
I would assume if necessary, we could brick and mortar in below the RSJ and existing wall. and add braces/plywood etc either side of the wall to hold it up?
