Hello,
We've recently moved to a modern/new-build house (11 years old) that has CH driven by an Potterton Suprima 50 boiler, fitted when the house was built (so also 11 years old).
Since we moved in, we’ve had a few problems with the boiler tripping out to lockout mode after just a few minutes of firing. A bit of research suggested it was the cause of the original factory-fitted circuit board in the Suprima 50, which apparently has an exposed wiring loom that could be prone to condensation build-up. We paid for a Gas Safe engineer to come fit a replacement board, with the enclosed wiring loom – assuming that would fix the problem.
In fact, this does indeed seem to have fixed the *original* problem, as the boiler will now fire more or less continuously for as long as needed. Recently, though, a new problem seems to have arisen, leading to lockout. Basically, after about 15 minutes of firing (certainly not nearly enough to bring a full tank to boiling point) an alarming bubbling noise starts coming from the pipes running under the upstairs floorboards that I assume must run from the boiler to the hot-water tank. This builds to a crescendo that, literally, sounds like a large kettle boiling (coupled with some metallic clanking from the hot-water tank). The Suprima 50 then trips out, and the boiling sound and metallic clanking stop essentially immediately.
To reiterate, when this point is reached the boiler will only have been firing for 15 minutes and the water in the tank (or rather, from from the taps) is *not* boiling. Sometimes, the running water will be little more than warm. Before this problem arose, I would set the boiler to fire for, say, 45-60 minutes for a piping-hot tank of water.
If I reset the boiler right away, it’ll then fire again – perhaps for another 15 minutes – before the same happens. As an experiment last night, I switched on the CH at the same time as the HW and – though I need to repeat the experiment to be confident of the result – this seem to quieten the noise and the boiler continued firing past 15 minutes.
So… any ideas as to what might be happening here?
Thanks,
Harry.
Thanks,
Harry.
