- Joined
- 27 Oct 2020
- Messages
- 112
- Reaction score
- 8
- Country
So let's say that I have unlocked the car with the keyfob, then I pull the boot handle - this somehow makes the reed switch break or make contact. This signal is sent to the car. Does it then think the boot is open? So if I lift the boot door up, and then pull the boot handle again, does it then think the boot door is closed? Surely it can't be anything to do with the switch under the boot handle, whether the car thinks the boot door is open or not?
I presume that in the mechanism that I saw behind the boot 'claw', the door lock metal rod and the central locking metal rod do something when they move, that then allows the door handle to open the boot. Otherwise (obviously) the door handle wouldn't unlock the 'claw', or you would never be able to lock the boot.
Jurassickpark, can you elaborate where the switch is, that has a hall sensor effect?
Old Salt - is the light switch on the metal bar thingy that pushes the 'claw' up and around it when you shut the boot? I haven't looked down there!
