Apologies if this has been explained before… but I can’t for the life of me search properly on this site! Using AND as described just makes it a part of the search results javascript:emoticon('') Confused
I want some advice before getting a pro in.
Kitchen
I have 3 double switches (above the worktop) and a number below (not sure if they are on the main circuit or just spurs of the 3 doubles).
I have read that you can:
Have as many spurs as sockets. The spurs can be connected direct to the main circuit or off the existing sockets. In my case 3 spurs (excluding those under the worktop).
Have as many FCU as you want (within reason) and connected them direct to the main circuit.
Question 1
How many 20Amp DP switches can you have, in my current configuration would it be 3 (excluding those under the worktop), because they need to be off spurs ? or
Question 2
Can a 20 Amp DP be wired directly to the main circuit (like an FCU) with a spur to an un-switched socket below the w/top to feed an appliance?
Last Question
I want to have easy access to switch off the appliances. There will be 6 appliances but I don’t really want 6 switches FCU/DP on show. Appliances are:
D/Washer
W/Machine
F/F
Hood
Hob ignition
Under Unit Lights.
(The under worktop sockets will not be in the right place and are excluded for the purpose of the below questions)
Could I do the following to reduce the number of FCU?:
For the Heavy power users:
FCU for DW
FCU for WM
FCU for FF
Not so heavy power users:
One FCU for Hood, Hob Ignition & Lights?
Or do I have the option to:
Heavy power users
20 Amp DP for DW
20 Amp DP for WM
20 Amp DP for FF
One 20 Amp DP for Hood, Hob Ignition & Lights?
Kitchen
Question 1
Question 2
Last Question
D/Washer
W/Machine
F/F
Hood
Hob ignition
Under Unit Lights.
FCU for DW
FCU for WM
FCU for FF
Heavy power users
20 Amp DP for DW
20 Amp DP for WM
20 Amp DP for FF
