If you've paid these guys you would have every right to pursue them through the courts for a refund and compensation to have that stuff put right.
The wiring is not only illegal it's lethally dangerous. They look like they can't even wire a plug, never mind do serious electrical work. Look at the way the wires are hanging out of the dishwasher plug.
The dishwasher's not installed correctly at all and should be standing on its feet, not on blocks of wood. This will cause vibration and may limit the airflow to the machine resulting in risks of overheating. The manufactures do provide full instructions for installation for a reason!
The situation with your wall is totally unacceptable.
The stopcock must absolutely be 100% accessible. As a previous poster said, it's there for a reason to isolate your house from the water mains if something bursts.
I'd consult a good solicitor and take a LOT of photographs. Those guys ought to be sued.
Also you said
"The two ends of the extension lead powering the oven/hop/dishwasher the exposed flex is from the oven. I can't actually reach the socket it's about 6" under the worktop, I got the photo by lying under the base unit. The extension lead was then tucked into the back of the oven base unit. "
Could you describe this more fully / provide photographs? That is beyond sloppy, it's actually ridiculous and extremely dangerous.
I would advise you not to use the oven under any circumstances if it is connected via an extension lead. You could cause a fire. I would also refrain from using the dishwasher until the electrical work is put right.
1) Call your solicitor
2) Get a letter sent to the company in question and give them a short period to come up with an acceptable settlement
3) If that fails, take them to court, they wouldn't have a leg to stand on. That is a total mess. You shouldn't have to put up with that or pay to put it right.
I'd estimate that could cost thousands to put right. You shouldn't be out of pocket for any of it and those cowboys deserve to pay up. That's not only a rip off it could actually kill you or cause your house to burn down.
Also, and this is important and should be done urgently:
Get an electrician in to survey the problems. I suspect that they've also over-fused your fuse box i.e. put in higher rated fuse wire than should be there. Particularly if the fuses were blowing quickly. There is a reason why fuses blow and it's not because the fuse is faulty.
Keep the bill and submit it to the company for payment together with your solicitor's letter.
