Kitchen tiling
Thanks GCOL again. Happy xmas and New Year to all.
I am off and rolling with the tiling. It is going ok and what I have done so far has passed the litmus test- the fiance!!!
In planning I did however muck up where the sockets are to be.
The kitchen installer placed a switch for the extractor fan very close to an electrical point. As such a tile is needs to go under the whole of the extractor switch and the socket.
How can I cut a whole in the centre of the tile?
Shall I just cut the tile down and then stick the pieces together?
Thanks again guys.
George
To do the job properly, you'll need to use an angle grinder (ideally with a diamond disc, but you'll probably get away with a cheap stone disc). Mark out the hole and make the cuts on the face of the tile. You'll notice that because the cutting wheel is round, it will not make a complete cut into the corner so you'll need to turn the tile over and finish the cuts from the back of the tile.
Thanks gcol.
I will see what B&Q have in the sale and go and buy one.
Any idea on what size I should buy?
