Would appreciate some advice:
Extended my kitchen by knocking down a wall to a utility room. The utility room incorporated a connection for an electric kiln used by the previous house owner. The cable is on a dedicated radial circuit to the CU. I want to move this cable (4mm) to supply my new single electric oven connected via a single socket / isolator. What rating fuse would be required for this circuit (cartridge type)? It currently has a 30 A fuse.
Under part P is it required for a registered electrician to move an existing power supply?
There is an existing oven power supply (4mm cable on a dedicated radial circuit) which I want to convert to a double socket and then extend the radial circuit for an additional socket for a TV. I want to use 2.5 mm cable for the extension since I will no longer be using the circuit as an oven power supply. Can I do this and put in a lower rating fuse in to protect the 2.5 mm cable? What rating fuse would be appropriate?
Thanks!
Thanks!
