Hi folks, i'm in need of advise please.
I am hanging a few wall cupboards in my kitchen and need to extend the socket outlet down the wall to just above the worktop as the socket is currently quite high up and fed a tall fridge/freezer.
Also going to put a small strip light under the cabinets to illuminate the worktop.
The current outlet will then be unused as it will be behind the units.
Do i wire into the old outlet and take a spur down the wall ? We really want 2 double outlets at worktop so wondered if a spur can supply this much or do i need to extend some other way ? Not sure at the moment if its on a ring main or radial or what cable sizes are.
Also the strip light under the cabinets needs a supply. Does this have to be from a lighting circuit or can i fit an switched fcu by the side of my socket outlets and take a feed from them but protecting with a 5 amp fuse ?
