Something you could try is to remove the timer board from a bathroom fan, mount it in a box thats fit for purpose, make the appropriate conns between the door feed/load receiver relay and perm. feed and in the same way as you connect a fan with run-on timer, connect the light to the output where the fan moter would be. Hope that makes sense.
nope that would be to easy, i suggested a timer relay and day night sensor but he wasnt interested. he just wants light on when door is open and off when shut. i called the manufacture for the impulse relay and they confirmed when voltage is applied the relay will change state until voltage is applied again. (i called twice spoke to two different people just to be safe,lol)
these are very useful - press once to turn the light on, press again to turn it off. You can have one by the front door, one by the back door of the garage - quite versatile really. Also available in a metaclad version for the more safety minded installer / client. Fattony, have you reminded your client of the existance of these devices?
In fact, what's wrong with a couple of PIRs operating the inside lights, one outside, one inside, then the lights come on when he approaches.
