lead colours on CCTV camera
3 Nov 2006
Bedfordshire
I have to re-connect a CCTV camera but do not have the information as to which lead is which. Hoping someone might recognise it and know the colours
Black cylindrical metal body 36 mm diameter and 53 mm long. Any labels that were on it have long gone.
One end is glass with the camera in the centre surrounded by 8 LEDs and one photo sensitive resistor. These are all inside the 36 mm diameter.
A single lead come out from the other end and this divides into 2 coax cables. One coax has a red core and one has a yellow core.
In the centre of this end is a threaded bush to mount the camera on an adjustable arm.
( I did not disconnect it )
Yellow video output... red wire 12+ black and outer shielding 0v , some cameras share this, some are separate black for 0v but if you put mulitmeter on black wire and shielding it nornally common connection..
