LED Bathroom Light
Cheers. Good to know it can work with what I've got anyway so I need one of those and some 2 core cable too and I'll be good. Thanks for all your help.
The 773 are no good for flex ( stranded conductors) so the flexes conductors would go into the 222 wagos
Is flex where the core is made up of strands? I guess I'd need to have a look if that's the case. Are the wires likely to be a mix of flex and non flex?
Also if I'm ordering a 2 core cable to go from the connectors to the light fitting does it matter what mm2 wiring I go with? Is there a minimum size I'll need to this application?
Yes flex is stranded ,and easier to work with than twin and earth cable . 0.75 mm² is what I would use. Your pictures of fixed wiring all appear to be twin and earth and 3 core and earth, and not stranded.
I prefer 221 series to be frank. But I think sfix only sell large quantities ,don't you have to buy 50 of them ?
Have a look at Toolstations click and collect website ,they do smaller packs of around ten ,no use if you don't have a branch near you though !!!
I've had a look and the set from Amazon makes more sense for me to get I think. Appreciate the suggestion though.
Just realised I definitely can do because it has that shelf and three slots at the end so that looks like a good option. I can get the junction box from Toolstation too.
