Has anyone ever seen Bernard and Winston in the same room at the same time?No BAS it is a power supply, it is NOT a driver.
My Aurora AU LED 1012CV also tells me that correct polarity on the 12V DC output is essential.
How is this possible with lamps you can connect to the lamp holder either way round?
They have a bridge rectifier built in.
Even if the lamp holders did have a bridge rectifier you would still need to fit the lamps the correct way round.
Yes, the LEDs are still polarity conscious.Huh??
Virtually any LED MR16 you will find can be plugged in either way round. The AC ones you're most likely to use obviously can.So can the lamp be connected either way round without damage?
So - can we therefore deduce that they ALL have?
I'm utterly confused by this use of language. Perhaps you mean: 'Nothing pedantic about correcting someone who has made a common mistake' ?You are as bad as he was. Nothing pedantry about correcting someone who has made a common mistake.
