D
Doggit
As the song goes, Potato, potahto, tomato, tomahto, Let's call the whole thing off.
Do LED lamps have a significant inrush current?
Now you're just being foolish. Whatever technical definition of MR16 you might be using, for the vast majority of people the vast majority of legacy halogen lamps called MR16 are AC 12V (possibly 5V or 24V) with a GU5.3 base. LED lamps called MR16 usually have a GU5.3 base but often don't have a two-inch multifacted reflector shell.You have already established in post 32 that they don't know what they are talking about. Do LED lamps have a significant inrush current? I don't think so. And what is all this talk about MR16s? Many, perhaps the majority of MR16s are 240 volts, so don't need a driver or power supply at all. I've a feeling this company does not even know what MR16 is.
It is anybody's guess whether a particular transformer can handle that for a few ms or not.
Why not, given that the resistance of a cold incandescent lamp filament is less than 0.1 x the resistance when it's hot?but with halogen lamps it wasn't necessary.
A transformer built with electronics may not be able to handle a transient overload caused by inrush current takne by the lamp.
Indeed. That is a transformerA transformer built with nothing more than two coils of wire on a magnetic core will handle that in rush without problems.
Not all LED MR16s are incorrectly described - some are indeed MR16s.LEDs referred to as MR16, though not correctly, can only be a 2inch reflector shaped lamp but can be any voltage and any base.
I'm starting to see why the word "pedantry" arose earlier. You are the only person who chooses deliberately to misunderstand what I and others have said. You could have decided to offer your knowledge without being disagreeable but instead prefer to sit on your ivory tower and pronounce that the entire world is wrong.No you are being foolish and the vast majority of people are misinformed, often by the people selling this stuff. MR16 is nothing to do with the base or operating voltage. LEDs referred to as MR16, though not correctly, can only be a 2inch reflector shaped lamp but can be any voltage and any base.
... nor pedantry.No ivory towers or pedantry.
No, he did not.You said, effectively, that the majority of people had the wrong idea of what MR16 meant.
The fact that there is no link between an MR16 envelope and a particular base does not affect the truth of what he wrote.for the vast majority of people the vast majority of legacy halogen lamps called MR16 are AC 12V (possibly 5V or 24V) with a GU5.3 base. LED lamps called MR16 usually have a GU5.3 base but often don't have a two-inch multifacted reflector shell.
