trying to make sure I am following 17th regs on cable concealment. In this case to do with extending circuit and/or using same channel for AV cables and power.
I have drawn two plans for starters as I know you like pictures
In plan 1, the power goes all the way to a socket behind TV. AV cables go in and out of a channel on other side of stud.
In plan 2, the flex from the TV goes through same behind wall channel as the AV cables. Does plan 2 fail because of mixing AV and power cables and because of the 50mm cable depth required for electrical cable concealment?? Any solution to this?
background....
The wall is an inner layer of 19mm plasterboard directly overlaid with an outer 12mm plasterboard. All on wooden studs. It is a wood framed building. There is what looks like fibreglass loft insulation in cavity behind the inner plasterboard.
Both plans extend the power circuit to give a socket or sockets nearer the TV
The existing 2gang socket would be converted to a 1G that leads to a 13A switched FCU that then leads to all power sockets for TV , dvd player etc.
There is a gap behind the approx 80mm depth studs to fish power cable through so I should be ok with the required 50mm depth regs when extending the circuit and concealing wire? At least 50mm on the other side of the new power cable run too.
I aim to use drywall pattress boxes with holes cut in them to allow a neat entry of AV cables in and out of the wall.
AV cables would enter and exit wall via brush plates like:
http://www.wickes.co.uk/Single-Gang-Brush-Faceplate/invt/204733?source=123_4
Or via a blank plate with holes drilled in and cut in two. Av cables go in/come out of pattress box and then put two pieces of blank plate back on with cable ends hanging out of drilled holes.
Ideally I would like to get a conduit for AV cables into the cavity behind the plasterboard but all I can think of is 65mm square guttering downpipe IF I can get it inside the wall without cutting huge pieces out of the wall. Fat chance.
On far left is an old brown cable aerial socket. Tempted to leave it be. I cant find where it leads and existing aerial (not used now) comes in through exterior wall !??!
Any help and advice appreciated. The AV forums don’t seem too hot on regs. Don’t mention D-line exterior conduit.
background....
