It was endecotp who supplied the diagram
That's certainly always going to be the safest way - although with that bizarre wiring shown in endecotp's diagram it theoretically might even be necessary to turn off two breakers! Thankfully, the chances of you ever encountering such weird wiring must be close to zero.Thanks for the diagram. I can see why it's not safe. It pays to be careful to switch off the breaker even if one is changing bulbs.
As is probably apparent from what I wrote/asked, I've also been through that thinking process and have failed to come up with even a half-sensible answer.I am trying to think of a reason for wiring it like that on purpose or where it would even be thought to be necessary.
Yes - but when would that be the only option?You only need one core going from the switch downstairs to the upstairs light! Plus earth. Assuming you're borrowing both lives from both circuits!
Never, but you were trying to think of a reason. Given how rare it is, clearly there are few compelling reasons, but if you only have one working core in the switch cable it would work.Yes - but when would that be the only option?
If memory serves me right one of the house with this two circut was wired in singles with Live and Neutral looped around the light switches with drops from some of the switches to round pin sockets below the switch. Two singles ( Neutral and Switched Live ) went up to the lamp.
