Lighting outside led earth
9 Jan 2022
Hi, I have a simple lighting circuit outside around some stables. They are fluorescent bulkhead type x 4. One broke in the middle so I've replaced it with an led bulkhead.
All fine but the LED doesn't need an earth. The previous ones did. Do I just connect the earth wires with a little connector and keep them in the new light fitting?
Also I'm going to replace all the older ones with leds ones eventually what do I do with the earth wire. Will it need to be disconnected or just left?
Thanks for your help
Read more: https://www.diynot.com/diy/threads/led-no-earth-in-external-circuit.584796/#ixzz7HyrTS8El
