Lights out RCB ?
So you can't drill the steel H section in case you weaken it but you can drill a 25mm hole in every wooden floor joist supported by it without any worries !! :oops:
Wooden floor joists holes are covered by a standard rule defined, I believe, in the original wood joist span tables which used to be published in the building reg approved documents. You can only drill along a certain section of the span though.
Steel beams though are usually only included in a building after a qualified designer has performed the appropriate load calculations, and there are no pre-determined rules of thumb defined in the approved documents.
So, whilst it may be perfectly OK in practice to perform your own estimate of the effect of drilling a hole, the general consensus is that the cost of drilling this hole legally (with paid-for calculations) is much higher that simply finding a better route.
There are often holes predrilled along the length. If you cannot find one then you may find a gap under, or more usually) around the end of the RSJ.
Glad you found the prob!
Just a thought, would any of the tests or test equipment been able to locate this fault?
You already knew there was a problem as you didn't have 230vAC between live/switched live. But with the circuit isolated, if you had connected the live/switched live at one end and measured the resistance between them at the other, you would have seen an open circuit reading.
It wouldn't have located exactly where the problem was - just which section of cable. That's why after identifying a fault it can be an absolute nightmare to find. Especially if it's an intermittent fault... :cry:
Can I just clarify because I'm always getting confused...
In lighting circuits you get SWITCHED FEED and SWITCHED LIVE? Two seperate cables with different operations?
Switch feed/permanent live are the same thing. As are switch return/switched live. ;)
So switch feed comes from the cu and switch return is the neutral oversleeved with brown?
No!
The permanent live goes to the switch. Out of the switch comes the switched live (oversleeved in brown, or old red)
When the switch is on, the switched live is live. It goes back up to the ceiling and into the lightbulb.
So when the switch is on, the switched live is live, goes to the lightbulb, and it lights.
In this method the neutral does not go to the switch.
The Twin and Earth cable (usually) has a red and a black, or a brown and a blue core, so people are often misled into thinking that it has a neutral in it. It doesn't. Both cores are L (though one is switched and one is permanent).
Do not think that all black (or blue) wires are Neutral.
This error leads to a very common fault causing a short-circuit when changing ceiling roses.
