Hello Peeps
Bit new to all this but here goes. I have just rwired the lighting circuit in my bungalow using the junction box method. I have run a 1.5mm cable from my consumer unit to my first light and so on and so forth to my last light. I connected the cable in the consumer unit and all is fine. i have noticed reading on this site that the lighting curcuit should be on a 6A MCB when i checked in my consumer unit i had connectd my lights on to 32A MCB. I swapped the wire as needed and tried the lights. As soon as i hit the first switch it tripped the RCD. I have checked all my wiring and cannot find a fault. If i put the wire back in a 32A MCB all is ok.
Where am i going wrong any help much appriciated
Thanks Lee
Thanks Lee
