Trouble is now I've found a pic of linear it doesn't have a conventional groove which allows the fitting of different gaskets like the ones I linked to earlier, from the above pic you can see that even with some compression it would still leave an area against the glass for water to pool although the op windows are worse than gazmans. I think glazing tape would be your only option IF you chose to remove the co-extruded bubble gasket but that would have to be with the explicit permission of the installer and in writing as not to void any warranty
