Live/Earth Reverse Fault
It is wrong to have 2 fuses in series of the same value.
So do you believe that it is 'wrong' to have a fused spur from, say, a ring final circuit? With such a spur, you would usually have a 13A fuse in the FCU and quite possibly a 13A fuse in a plug which was plugged into one of the sockets supplied by the spur?
I agree that, with such an an arrangement, there is no telling which (or both) fuses would operate in the case of an over-current situation, but that doesn't make it 'wrong'.
On the other hand, to remove the FCU if it does happen to be a fused spur (for good reason) definitely would be wrong.
Kind Regards, John
My point was if it was wrong initially, now is the time to put it right.
But you must prove it was installed wrongly first. I would consider removing a protective device from a circuit for an isolator, could in fact introduce a potential dangerous occurrence.
