Reversed Live/Neutral
RichA said:
I guess I am suprised that if this is the wrong way round that all my electronic items seem to work. i.e. pc, tv, etc ???
they wont be too bothered about polarity, since 230V is between phase and neutral to the appliance. its just that it will switch the now neutral and not phase which could cause a shock/death. its not something that should be left untreated.
or, it could just be the socket the plumber tested from was mis-wired
As danlightbulb rightly said, all the equipment works on AC and doesn't care if you have an unsafe installation.
(bah, too slow :oops: )
It doesnt matter if it was 10 years ago. The electrician must give you and Electrical installation Certificate that confirms that the work he did (changing the fuseboard) conormed to BS7671. There will also have been a schedule of test results.
Changing a consumer unit is notifiable under Building regs Part P and he is legally obliged to notify the local authority to conply with the legislation (=law!). This applied to work of this nature carried out since 1st january 2005.
TTC
