Kevin, please explain the logic of pumping cold air into the upstairs of a home to cure condensation?
If you want to dilute the warm wet air in your home you traditionally just open a window (this costs a lot less than £400) and let some of the warm wet air out and let some of the cold dry air in.
The air outside is nearly always drier than the air indoors.
But opening windows in winter, lets that warm air out, warm air that you will have to pay to heat and lets in cold air that you will need to heat at more cost.
So why produce water vapour in the first place?
Why not buy a hygrometer for a few pounds and see how wet the air is in your home.
One that has an accuracy of + or - one percent and a memory will do the trick.
Then you can measure progress
Why not change your life style, stop making so much water vapour and let the problem go away?
Water vapour that turns into condensation is caused by washing, cooking, drying things on radiators and breathing.
The process relies on the fact that warm air holds more water vapour than cold.
Example:
Warm air at 30 C holds 30 ml of water
Warm air at 20 C holds 18 ml of water
Cool air at Zero C holds 5 ml of water
This is per cubic metre of air.
You can see that turning your heating down
or turning your heating off, causes the water vapour in the air to condense onto or into the windows, walls, beds and other furnishings.
Usually the first sign is windows running with condensation in the morning, where the temperature in between the window and the curtains or blinds has dropped during the night.
The perfect solution is to hold the same temperature for 24/7 this will cause the warm air to hold the moisture, it will warm the walls and other things and you will have a far more pleasant home.
You will no doubt have noticed that during the day the warm air moving past the windows helps keep them warm and dry the condensation only forms at night.
If you have extractor fans in your kitchen and bathroom use them and leave them running for twenty minutes after use or until the humidity has gone away - (you can buy extractor fan with humidity control) this is cheaper than buying new kit to do the same job.
In any event, pumping in cold dry air, merely pressurizes the home and help push the warm wet air into the walls, making the walls damp and the home unpleasnt.
