I have to drill right through some softwood which is 220mm across as I want to sink in some LED lights.
I have tried drilling from both sides but it doesn't give a clean enough hole to pass the plug/cable through.
The only bits I can see in the sheds long enough are all masonary bits - would these be any good at all for going through softwood - the hole at the front will already be started with a 25mm "spade" type bit as that is what the light fittings need for their housing.
Alternatively any suggestions as to specific long bits?
Cheers.
Cheers.
