FWIW, the last one of those I dissected appeared to have taps on a single winding - hence one common 'end'.Are the different windings all completely separate, or are they commoned at one end?
Kind Regards, John
Sorry, I don't know. I'd have take it all apart again to try to identify what the connection layout is. I haven't been able to find a wiring diagram anywhere.Are the different windings all completely separate, or are they commoned at one end?
For the moment I've left the switch on medium setting and we control on/off by switching the connector box (where flex meets up with cabling).Also, decide if you do actually need all 3 speeds, or only 2, and if you do need all 3 if there's one which you use most often, i.e. the one you mostly use when turning the fan on.
I've made a new part for a switch (for a compressor) using some 2-part epoxy repair putty. Can be moulded like Plasticine, sets in about an hour.It might be possible to create a new mechanism using a casting resin. Using the bits of the broken one to make a mould. A lot of work but can be worthwhile.
Th company I used about 20 years ago no longer trades but this
http://www.ecfibreglasssupplies.co.uk/c-116-polyester-casting-resins.aspx
company appears to supply the resin and the moulding materials.
It's almost certainly just a simple 4-position switch for a tapped winding on a simple motor.
It almost certainly does not need to be DP. It almost certainly doesn't matter if it's BBM or MBM.
"" the right electrical rating "" of course, just decide exactly what is the right electrical rating.It almost certainly could be replaced with any rotary switch with the right electrical rating, either in the hood or in an enclosure nearby.
The lamp is controlled by a separate on/off switch.And if I read correctly the switch also controls the lamp so a second pole is needed.
No it won't.If a Make Before Break ( MBB ) is used then as it moves from one position to the next it will put a short across part of the motor coil.
L connected to two taps - what current will flow where?If the motor is running this short will be high current, enough to damage switch contacts and possibly damage the windings.
What sort of size are these motors, and what currents and voltages are involved?Some switches used for tap changing on motors even though they are Break Before Make ( BBM ) are designed to have increased separation between the fixed contacts to ensure contacts are not damaged by maintained arcing when tap changing happens.
Yes - the OP will need to know what load the motor is to be able to select an appropriate switch, e.g. at least 230V, at least 1A inductive. Or whatever."" the right electrical rating "" of course, just decide exactly what is the right electrical rating.
I didn't read that.And if I read correctly the switch also controls the lamp so a second pole is needed.
?? What is your understanding of the functionality of a MBB switch?No it won't.If a Make Before Break ( MBB ) is used then as it moves from one position to the next it will put a short across part of the motor coil.
What about the voltage/current induced into the 'shorted' part of the coil? AFAICS, the connection to L (or anything else) is not relevant.L connected to two taps - what current will flow where?If the motor is running this short will be high current, enough to damage switch contacts and possibly damage the windings.
Looks like an auto transformer with a shorted winding.
