I had one loose tile in my bathroom which I have removed. It was in a corner above the bath and I suspect water got behind it and caused the adhesive to let go, possibly because I think the grout gap in the corner is too small. Or it could be because the adhesive had started to go off before the tile was fitted and it just didn't grab properly. The surrounding tiles are all solid. The wall is ready for the tile to go back (adhesive removed, unibonded and holes filled).
I have two questions:
I have a diamond edge tile saw, should I risk trying to take about 1mm off the edge so I can get a proper grout gap bearing in mind I have no spare tiles?
What can I use to re-fix just one porcelain tile approx 200 x 250 mm?
Many thanks[/b]
Many thanks[/b]
