A
ALEC1
Joe, we have tables and calculations for that...of course it will make a difference...
Worcester Bosch also say the pipe shoukd be a minimum of 22mm uninterrupted between the meter and the boiler...How many meters away is the meter...I reckon about 10m..
The friend who serviced it said it was a bit low but not to worry about it.
Has anyone done the maths to see if a section of larger diameter pipe will make any realistic difference? Pressure has nothing to do with volume other than with a miniscule amount of friction.
It doesn't make sense according the physics that I studied. If I replace half my garden hose with a bigger diameter it won't make hardly any difference to the water volume that comes out .
If you get a length electric cable and put 240 volts down it and then make half of it a double thickness, do you really think the voltage (pressure) will rise? It can carry more current (volume). Gas pipes follow the same laws of physics. They are universal laws.
Stop bullshltting Joe and work it out.
Just seen Razor's post...
