- Joined
- 28 Oct 2005
- Messages
- 31,281
- Reaction score
- 1,997
- Country
Who's not worthy? Stick to fitting door bells!
Bet your good with bell ends?
Not little ones like yours. Thanks all the same for the offer, darling.
But we're talking about gas supplied at 20mb not electricity at 240v. You can only use an analogy between the two so far...
Go and give advice on something you understand for a change
If you get a length electric cable and put 240 volts down it and then make half of it a double thickness, do you really think the voltage (pressure) will rise? It can carry more current (volume). Gas pipes follow the same laws of physics. They are universal laws.
Have u any idea how foolish this makes you look?
If you don't understand science - then do please be quiet.
working pressure at the boiler was only 15mbar (which he said was a bit low), he checked it at the meter and it was 19mbar . it is 22mm, about 13m long and I think it has got 4 elbows)
would replacing a 7m section at the start with larger diameter help?
Yes, and artificial eyes are obviously made of glass; got to be, otherwise you couldn't see through them.....Yes. Pressure and volume. Water, electrics, gas etc - all follow the same laws of physics.
Thank god the saviour of the gas industry has arrived.... We can all sleep safe in our beds!
