Hi Chjee / Folks
Apologies for the length of time posting a reply as I have been abroad till a month back! I have not found a solution yet! My Compression test showed no problems. Car would run smoothly from start but when it reaches normal operating temperature it would sometimes misfire always cylinders 3 & 4 even when coming of a motorway and stopping, it would misfire at idle!
This is the strange thing! When car is stationery uphill the hill the engine rocks back and forth noticeable! If it is stationery downhill 9 times of 10 it is smooth as silk! I have changed the fuel filter, Spark Plugs, Leads, Temp Sensor, cleaned throttle body, EGR Valve but same old problems.
Had a Lambda sensor problem with sensor near Cat replaced that with a generic sensor (Lucas make) Now get get CEL fault short to B+ whatever that means! One mechanic thought it might be fuel injector intermittent fault!
