I think this is a case where the regulation is wrong. Telling people would result in their installations being safer.
You know that I agree with that, and the person most like to have had a problem with 'advising people to do something non-compliant with what the regulation actually says' has not yet said anything - so fair enough!
Possibly, but it's a job to know where to stop -
Agreed. What one has to try to decide is where 'increasing information and comprehensiveness' stops and 'overwhelming with information, and making it difficult to see the wood for the trees' starts.
True, but I wanted to cover all possibilities and did not want a reaction to be "Yeah but what if?" to something I had not included.
Yes, I understand that. However, since #2, #4 and #5 are all examples in which there no extraneous-c-ps and so no bonding is needed at all, I wonder if it might make sense to separate them from the otehrs and given them a separate 'title' of 'situations in which no bonding is required. Let's face it, #1 is by far the most common situation, and even #3 is fairly rare (for water) - so it's just those two which are of primary importance.
However, given our other discussions, you might want to consider expanding #3 to include gas pipes, primarily by redefining the grey bits as being "plastic pipe/insulating section
/meter". In fact, it's also just occurred to me that the 'meter' business also applies to indoor
water meters - and I am reminded that, in this respect, the regulation is
very wrong in relation to my daughter's house, since there are a couple of metres of copper pipe under her kitchen sink etc. between water pipe entry and a meter.
Yes, I did think about SB but it will soon be a thing of the past with RCDs and there are so many variations.
Indeed. Even if you did consider addressing it, it would be a totally separate exercise.
IF - big IF - SB is required, it fundamentally boils down to: bond 'M' and 'T' pipes and not 'isolated', doesn't it?
Yes, I think so, but the problem we usually discuss is in determining/confirming 'T' and 'isolated', isn't it - with you usually saying that 'testing is required'?
Also should I change the title to something like "electrical connections of household pipework" rather than the narrow MPB?
I think you could probably usefully change the title, but I'm not certain about what you propose there. I'll think about it. You may even have to consider including the dreaded 'E-word' (presumably 'in quotes', followed by 'a lecture' in the text!), since many DIYers might be looking for that, rather than 'Bonding'!
Kind Regards, John
