- Joined
- 14 Sep 2009
- Messages
- 51
- Reaction score
- 2
- Country
The main stopcock to my terraced house is located in the pavement outside my house under a cover (I do have a separate stopcock under my sink).
I have a water meter which is situated adjacent to the stopcock (ie on pavement under cover).
I discovered a while ago that the stopcock which shuts off the water supply to my house (ie the one under the cover in pavement) is linked to the water supply of the next terrace.
For total clarity, by 'linked' I mean that if the stopcock in the pavement is turned off then the water supply to both houses is shut off.
I wanted to separate this closing mechanism so that each terrace will be independent of each other.
As stated above, I have a water meter but the adjacent terrace seemingly does not (or at least there is no sign of it where my meter is situated).
I did speak to CS of my water utility and the person I spoke to said that a shared stopcock was not unusual in this instance and that installing a second stopcocks (one for each house) could be done.
Has anybody on these forums gone through such a process. I am trying to get an idea of time required, cost, plus any potential for aggro or issues that could arise.
I was also wondering if there were any pitfalls to be aware in such cases. Or is such a process relative hassle free?
I will be contacting the water utility again but would appreciate any info or insight to this process prior to calling them again.
Many thanks
Many thanks
