If the hexagonal nut adjacent to my water meter (under cover in pavement as seen in photo above ) is turned off, then this stops water to both properties.
I did not know that my water meter had a valve in the meter chamber so have never tried to turn it off to confirm.
So should my neighbour ask to have a water meter fitted to their branch of the water supply? Is that the best/easiest option? Would installing a water meter be free or would that incur a cost?
If I called my water supplier and asked them to send someone to come out and have a look in order to assess the situation, would the water supplier do this?
Cheers
For clarity it is Thames Water.Nige F said:
Well if it is Southern Water then there is a £75 charge including initial assesment - there is a form on their website . Looks to me like the most straightforward option . and cheaper than litigation
adlplumbing said:
southern water have made mistake their fore they have to correct
water meter should not have been fitted their for they owe the op money
giving independant supply could be a form of compensation.
adlplumbing & Agile, you are both clearly stating that the meter has been incorrectly fitted and that I have been incurring costs for both households.Agile said:
All you need to do is to tell the water co the meter has wrongly been fitted to supply both properties!
Ask for ( at least ) half all the metered charges to be returned to you!
Get them to get it corrected ASAP and that will then enable their property to be isolated on its own.
I am getting confused here which happens more often nowadays.Agile said:
The meter and its valve are an integral unit. IF the neighbour is turned off by your meter valve then her consumption MUST be going through her meter!
