Main Stopcock Shared - Require Info
If that hexagonal nut in the meter chamber turns both houses off, then that meter is providing BOTH properties. Ask your neighbour to run a tap and check the meter to see if it's moving.
If it bothers you that much then it would be cheaper to pay for an internal stop cock to be fitted at your neighbours house.
That meter needs checking tho. If it is feeding both houses then I would be onto UU and kicking off big time.
