Good evening all, I am new here and by no means an electrician and I hope you can help me. I have purchased a Manrose MF 100 standard fan without timer and I have a dilemma regarding the wiring. The fan I have removed had a timer and this one doesn't. I wired the main E N L into a fused switch, as is now required, then went on feed a cable to the fan unit and connected the N L. When the power was reconnected the fan came straight on and obviously would only turn off at the newly connected fused switch, I wasn't surprised when this happened as there is no switch feed from the light switch. Obviously I have wired it incorrectly and the question is, how the hell do I get it to turn on and off with the light switch?
I have mains cable E N L and a second cable with only E L which I assume is the switch cable which are already set up in the light switch, the only connections points I have in the fan unit are labelled N L1 L2 along with 2 points with not to be used written on them.
In anticipacion, Phil
