The set up stated above using isolator switch is easiest option but can't see it being to difficult to feed a new cable down, and the connections, at switch, of the new cable would be what?
If you fit a new cable it would have earth, neutral, permanent live and switched live.
You don't currently need the permanent live, but it would be wise to keep it available.
