Just because it's possible, doesn't mean you should do it.a black and decker bog standard hammer drill.
Maybe but that drill lives a second life as a hand me down, and my wrists are renowned for their strength!Just because it's possible, doesn't mean you should do it.
20mm will be exceeding the specification for that type of drill and when the bit jams in the hole, the drill will be destroyed along with your wrist.
Will that make SDS bits go round and round?I don't have an SDS drill (apart from a screwfix titan special which I only use for breaking things up)
It can depending on the mode, but I only use it on riprap mode because the chuck thing is about what you'd expect on a drill of that cost.Will that make SDS bits go round and round?
Yeah mines a Titan, but it sounds like I splashed out more than you and got the version with all the accessories, so I have a standard Chuck adaptor and various low quality looking drill bitsSounds like the one i have, less than 50 pound in screwfix i think, i used it to take down a garden wall, its quite heavy duty and does a good job for the price and not too heavy so you can go at it for a while, though tends to get hot after an hour.
Coupled up with some cheap ebay chisels with sds shafts, it done the job, you turn off the rotation with a lever on the side, or you can use as a drill with sds bits, dont recall if you can turn off the impact and use an sds chuck.
There would be no point, SDS is used on high torque drills because they don't slip and the hammer action can transfer better. As soon as you put a normal Chuck in between you've lost all the benefits. It's the drill itself that needs to be SDS.i don't have a sds only a BOSCH PSB 680 RE.user manual says concrete 14mm i was thinking of 14mm & if cable can't go through ( water feature type cable ) try to enlarge with bigger bit ,can only drill from outside because it's hard to work out where the bit will come through ,
also i see you can change from SDS by using a chuck adapter, but don't see any adapters to change to SDS
