- Joined
- 27 Nov 2024
- Messages
- 48
- Reaction score
- 6
- Country
@opps
It's the yellowing within weeks that makes oil based useless.
I glossed mother in laws lounge 2 years ago and it's still brilliant white.
This is where I'm puzzled.
Manufacturers said years ago there is no improvement or development in oil based paints anymore. All they do is change formula to meet the chemical requirements as law changes. At one point Dulux had a label on tin saying this. They just keep manufacturering as there is a demand for it.
I've not used any in last 10 years even outside
How about Crown PX4 or Bedec All Prime? ......better opacity ? .....then over again or a specific acrylic undercoat ?Going over old oil gloss I prefer to use zinsser BIN. It sticks solid but no opacity so after 2 hours apply a coat of acrylic primer.
I have been using BIN aqua as a primer over old gloss and well impressed. Don't half stick with great opacity.
As for oil undercoat it stinks. Cure time is said to be 24h but I think it needs a few days and I could wait that long.
You just got to get used to the different application characteristics of water-based paints.
Oil undercoat for me , primer acrylic is fine thoughI have used waterbased finishes over oil based undercoat in the past, but if you don't wait a couple of days the waterbased top coat may develop fish-eyes because the solvents are still being released.
I am old skool. I can can get a far flatter finish with oil based paints (adding Owatrol oil).
As a finishing coat surely it's oil based.....even ones with just a touch of dryerWaterbased paints definitely have some advantages (eg smell, drying times) but, in the main, they are less durable, particularly in areas of high traffic where the oils in our skin make them become soft. I have never used waterbased gloss, but I have seen numerous examples of waterbased eggshell window sills with black marks because the customer puts his (ferrous) keys or coins on the sill.
What acrylic primer do you normally use after you have given the gloss coat a bin ?Going over old oil gloss I prefer to use zinsser BIN. It sticks solid but no opacity so after 2 hours apply a coat of acrylic primer.
Leyland acrylic primer is good.
Bullseye 123 is a different product to BIN
Don't stick so well. Won't block knots that grin through old gloss.
Not so fast drying.
Very limited stain blocking.
Much thicker material so have to be more careful applying.
Takes days to fully cure although you can paint over same day. I found it will scratch off a bit Vs BIN that don't
And leyland , mcphersons ...in both acrylic and oil ... seems to be a lot less cost than crown , dulux or johnstonesLeyland acrylic primer is good.
Not so fast drying.
