I am currently renovating my Victorian home and have discovered in a number of areas that decisions are needed which are usually made by tradesmen based on their knowledge of regulations and regularly ignore science. For example, I am currently considering ventilation, ignored the regulations and using common sense. Why do I need it - I like to be comfortable and healthy.
Cutting to the chase it became apparent that I needed to avoid mould growth, control humidity and remove odours. The answer I came up with was to use a humidistat to turn on an extract fan at a given level of humidity. Luckily I checked what humidity is and didn't rely on my remembered knowledge. This leads me to ask the question: If the humidity level is, as it is here today, 69% does that mean an extractor fan set to 60% would work constantly?
Positioning fans in the areas where moisture is most likely to be concentrated seemed sensible so I decided to talk to the experts. Thats when I discovered that the experts (technical department of extract fan manufacturer) are only concerned with selling whichever model of their fan meets regulations in a given situation.
My research suggests to me that mould starts to grow at around 55% humidity so I should look to extract damp air above that level but fans generally work on two settings 60% and 90% - is there a scientific reason for this and at what level of humidity should I set my fan to operate?
Experts talk about air flow in litres per second and how many air changes are required per hour. Taken together this suggests it is possible to calculate which is the best fan for a particular room but regulations get in the way and fan manufacturers say that the size of the room is irrelevant - maybe to regulations but surely not to achieving a healthy environment. Do I need a fan with a greater capacity for a larger room and if not, why not?
