Hi there
At the moment I have an indirect thermal store type set up with a gas boiler. The thermal store is in the loft it looks like this
It was fitted about 5 years ago and its made by this company and I think this is their current version
http://www.albionwaterheaters.com/product-combination-cylinders.html
On the whole I'm happy with it, I do have an issue when it comes to maintenance as most jobbing plumbers don't seem to understand it and say something like.......'never seen that before mate, you should have got a mega flo'
I do find though that if I'm running one shower and then run another at the same time the water temp drops.
Now my loft conversion has just started and if I were to make a change now is the time to do it. So the questions are
1) Is there any benefit to me changing over to a Mega Flo?
2) Should I keep the current system but perhaps upgrade the thermal store. I've been reading about modern ones with ?heat plate exchangers or something which are meant to be better.
(At present there are three shower rooms and one bath in the house once the loft conversion is done there will be four showers. There will be about 25 rads)
