If the wall is rather fragile a disc cutter with a diamond blade will cut out the outline carefully, and can also cut the inside of the outline up a bit to make removal easier. I have a dust extraction attachment on mine otherwise it makes rather a lot of mess...
Ah but have you ever seen double sided boxes? A friend has one in his house, with a single socket fitted either side.I've SEEN double 16mm boxes
