Duplicate deleted
I was deferring to you as someone who is probably wiser than I am!You're a member of the public. When do you expect it?
A further point for clarification is that plastic enclosures manufactured from 960 degree glow-wire rated material would not be classified as ‘non-combustible’ in the context of this regulation.But it does. It requires compliance with BS EN 61439-3. The IEC Working Group who wrote the standard from which the BS EN is derived (without technical change) felt that the hot wire test was adequate verification of non-combustibility.If it does not require compliance with a European standard which does, then it has no meaning.
The wording that follows the reference to the product standard is redundant.
How on earth is this regulation going to be workable, let alone enforceable/policeable?
Indeed, they appear to be 'knee-jerking'. I don't really know (but certainly am not convinced) what effect the change will have on fires but, as I've said before, I'll be fairly surprised if a widespread change to metal CUs does not result in an increase in electric shocks, some of which may well be fatal ones.Hence the manufacturers playing safe and making their entire ranges out of steel.How on earth is this regulation going to be workable, let alone enforceable/policeable?
