I am currently planning to have an existing consumer unit replaced with a new dual RCD box meeting 17th edition regs. I have two questions regarding the current regulations.
1. As the wiring for the new smoke alarms will be within 50mm of the surace, can the circuit be run off one of the RCD supplies or does it require a dedicated RCBO?
2. For neatness I was planning to run the meter tails into the CU from the back. The tails would be routed for about 300mm inside a cavity wall, albeit one created using a fire-proof board (SuperLux). Would this plan conform to regulations?
Many thanks in advance for any advice offered.
