I am currently building a new property and am currently on first fix for the electrics. I am using the council for electrical inspection.
My problem
CU near the incoming supply that supplies the basement and Garage, however I want to put another CU under the stairs.
The distance is approximately 16 meters from the incoming supply to the location of the CU under the stairs.
I am looking at running 35mm individual tails to the CU with a 16mm earth, they will be run in the space between the ground floor and the basement and will not be exposed.
Can you see any problems with this.
My problem
